Re: Clutch Replacement
geschrieben von:
lucio
Datum: 06. Juni 2019 15:42
great thanks for getting back
my mechanic told me to try and find the replacement bushes do you have any idea where i can buy them?
so what your saying is that depending on the vehicle vin number will determine which clutch i need to purchase and the main issue is that certain vin numbers use different release bearings?
the clutch seems to slip especially in 5th gear, is this a common problem for the mb100 since it is getting stuck?
many thanks
lucio
