Re: When glow plug goes out engine does not turn over
geschrieben von: roger gibbons ()
Datum: 21. November 2019 20:03
hi
Discovered some of the plastic insulation around the main cable coming out of the new starter motor has melted away.you are right it is very close to the exhaust pipe.
Will put some insulation around exposed wire when I get a chance
Your theory was correct.. thank yoh
When glow plug goes out engine does not turn over 422 roger gibbons 11.11.19 16:39
Re: When glow plug goes out engine does not turn over 272 Devil-Kutter 12.11.19 06:13
Re: When glow plug goes out engine does not turn over 285 Südbaden MB 100 12.11.19 11:03
Re: When glow plug goes out engine does not turn over 269 Südbaden MB 100 11.11.19 21:35
Re: When glow plug goes out engine does not turn over 247 roger gibbons 21.11.19 20:03
