Re: When glow plug goes out engine does not turn over
geschrieben von: Südbaden MB 100 ()
Datum: 12. November 2019 11:03
yes i thought of the masseband -ground cable also,
but since the failire apears only when the Motor is hot ( and so the starter in the near visinity of the exhaust pipe) ist a sure bet that the new starter is the Problem with ist cheap China Switch.
But if the failure shows also when the Motor (exhaust pipes) are cold,
then the most probable cause is what devilkutter mentioned with the cround cable
It is a common Problem with aftermarket Starters that the Switch does not engage when the starter is heated due it´s Position next to the exhaust pipe.
When glow plug goes out engine does not turn over 417 roger gibbons 11.11.19 16:39
Re: When glow plug goes out engine does not turn over 268 Devil-Kutter 12.11.19 06:13
Re: When glow plug goes out engine does not turn over 280 Südbaden MB 100 12.11.19 11:03
Re: When glow plug goes out engine does not turn over 264 Südbaden MB 100 11.11.19 21:35
Re: When glow plug goes out engine does not turn over 243 roger gibbons 21.11.19 20:03
