Re: When glow plug goes out engine does not turn over
geschrieben von: Südbaden MB 100 ()
Datum: 11. November 2019 21:35
Keywords for me :
a) new starter
b) when engine is hot
Thats a known Problem, because the aftermarket starter are not shielded well enough against heat. So the magnet Switch (Little device on top of the starter) is hanging.
It might as well be, because aftermarket Starters use a quickly evabporating
grease in the said Little starter device.
In any case, no Problem to start nayway, if you open up the Motor cover and use
a hammer to give that Little starter devive a notch with it.
It will engage imitiate and your Motor will start over.
Report back please smileys with beer
When glow plug goes out engine does not turn over 422 roger gibbons 11.11.19 16:39
Re: When glow plug goes out engine does not turn over 272 Devil-Kutter 12.11.19 06:13
Re: When glow plug goes out engine does not turn over 286 Südbaden MB 100 12.11.19 11:03
Re: When glow plug goes out engine does not turn over 269 Südbaden MB 100 11.11.19 21:35
Re: When glow plug goes out engine does not turn over 248 roger gibbons 21.11.19 20:03
