Re: cracked block, new engine
geschrieben von: rainer(berlin) ()
Datum: 11. November 2018 09:49
Hello,flushing and new thermostat:
1)The thermostat has to be in the right position,the little arrow/mark must be on the top.Look
If not on the right position the thermostat himself will hamper the right flow and going up the hill the machine gets too hot.
2)The little bypass for venting in the thermostatcasing has to be clean.
3)After filling in new coolant process off venting and refilling is not to forget.
good luck
cracked block, new engine 553 roger gibbons 10.11.18 18:41
Re: cracked block, new engine 379 blacky 10.11.18 20:57
Re: cracked block, new engine 370 roger gibbons 10.11.18 21:55
Re: cracked block, new engine 369 roger gibbons 10.11.18 21:51
Re: cracked block, new engine 384 rainer(berlin) 11.11.18 09:49
Re: cracked block, new engine 366 roger gibbons 11.11.18 11:07
