cracked block, new engine
geschrieben von: roger gibbons ()
Datum: 10. November 2018 18:41
hi all, my engine overheats going up hill, my mechanic has looked at the head gasket and says its good. i am having the head pressure tested for cracks. if the head is not cracked, and its the block cracked, i know i have big problem
does anyone know where i can get another block from, or even another engine.
any ideas what else may have caused engine to overheat going uphill. i had the engine flushed of water as part of a service, maybe a cylinder head sealant was flushed out as well. the overheating has only happened since the system was flushed. i hope someone can help, i am pulling my hair out with worry.
also is there another model of engine that would replace the one i have, maybe the 5 cylinder. my vehicle is a 1992 2.4 diesel. it has been running so well.
cracked block, new engine 552 roger gibbons 10.11.18 18:41
Re: cracked block, new engine 379 blacky 10.11.18 20:57
Re: cracked block, new engine 370 roger gibbons 10.11.18 21:55
Re: cracked block, new engine 369 roger gibbons 10.11.18 21:51
Re: cracked block, new engine 384 rainer(berlin) 11.11.18 09:49
Re: cracked block, new engine 366 roger gibbons 11.11.18 11:07
In diesem Forum d├╝rfen leider nur registrierte Teilnehmer schreiben.
